Autostick
SRT8GUY
Autostick
Post by SRT8GUY »
Why is it that some owners of 2006 300csrt8 have no problem disabling the autostick and some owners do ?
Jected
RE: Autostick
Post by Jected »
Apparently there is a program difference in the TCM on 05/06 LX's to that of the 07's. Why....who knows but I hope Diablo sort this out ASAP. Its terrible the way it is, its not right and not how the product nor a car like this should be left....unfinished.
07 300C SRT8
RDP built 426/RDP-Bullet/Harrop supercharger(Boost 20psi)/HP/F custom fuel &Intercooler system/Nitrous setup/DSS 1000hp Half Shafts/Kooks Headers/Zoomers cat back/Precision Industries 3200
SRT8GUY
RE: Autostick
Post by SRT8GUY »
I hope Diablo get the problem sortd out
10SecS4
RE: Autostick
Post by 10SecS4 »
By "disabling the autostick", are you saying that you want to bounce off the rev limiter when in Autostick, as opposed to it automatically upshifting? If so, there should be no reason why you can't disable the auto upshift by choosing the appropriate option in the Predator, assuming you do in fact have a 2006 SRT-8.
If by "disabling the autostick," you're referring to wanting the opposite; that is, you want it to automatically upshift in Autostick instead of it bouncing off the rev limiter, you will need to upgrade to the latest TCM firmware which is the "AK" flash. The AK is the part number suffix that represents the latest TCM firmware for the '06 SRT-8. You cannot do this with the Predator. You would need to take the car to the dealer to have the flash performed. The good news is there's a TSB on this and it's located here:
http://www.wkjeeps.com/misc/LX/TSB/TSB_2102006.pdf
Once you get the "AK" flash, you will be able to enable or disable the auto upshift depending on how you configure the Predator. Note: the "AK" flash is the only known TCM which supports both features.
10SecS4
Re: RE: Autostick
Post by 10SecS4 »
Jected wrote:Apparently there is a program difference in the TCM on 05/06 LX's to that of the 07's. Why....who knows but I hope Diablo sort this out ASAP. Its terrible the way it is, its not right and not how the product nor a car like this should be left....unfinished.
There is nothing for Diablo to sort out. All '05/'06 TCMs except for the "AK" flash support only the "paddle hold" feature. All '07 TCMs support only the "paddle kick" feature. The "AK" flash is the only TCM which supports both of these features. There is nothing for Diablo to work on or sort out.
SRT8GUY
Re: RE: Autostick
Post by SRT8GUY »
10SecS4 wrote:By "disabling the autostick", are you saying that you want to bounce off the rev limiter when in Autostick, as opposed to it automatically upshifting? If so, there should be no reason why you can't disable the auto upshift by choosing the appropriate option in the Predator, assuming you do in fact have a 2006 SRT-8.
I do have the TSB flash for the delay 1-2 shit at WOT
10SecS4
RE: Re: RE: Autostick
Post by 10SecS4 »
SRT8GUY wrote:I do have the TSB flash for the delay 1-2 shit at WOT
But are you the one having a problem? Or was your original post in reference to other 06 SRT-8 owners?
If you have the TSB flash, there's no reason why the Autostick options in the Predator should not be working for you. Please clarify what exactly your problem is, assuming there is one.
SRT8GUY
Re: RE: Re: RE: Autostick
Post by SRT8GUY »
Am not the one with any problem in my first post i was asking why it work with some 06 300srt8's and not otheres but i found out that it works for my 06 300srt8
NetNathan
RE: Re: RE: Re: RE: Autostick
Post by NetNathan »
My '06 has the TCM update for "AutoUpShift" (Paddle Kick?) in AutoStick.
With my Predator I can freely switch between "Paddle Hold" or "Paddle Kick". I am on version 16a, next I am going to try it with version 17.
I am happy to have this working, however depressed because we were told that we would be able to adjust shift points.... of course we were also told we would have torque management adjustments.
The raised shift points are nice but they should be adjustable. Diablo stated they could not adjust shift points.....but then how did they do the "Raised" shift points?????
2006 Charger SRT8
Inferno Red with All Factory Options / Groups
Side moldings and rear ram's head shaved, Diablosport Trinity 2 Platinum, Billett Technology bling
MPR Motorsports built 6.1 based/392 NA Stroker, BBK 85mm TB, TranZformer, Kooks Long Tubes, 3.70 LSD Hellcat rear cradle
