06 monte COT, Fan speeds a knock sensor
RE: Re: RE: 06 monte COT, Fan speeds a knock sensor
you have an aftermarket MAF sensor on there???? bad bad bad... get the stock one back on there asap.. and also leave the screen in it....
no need for an aftermarket MAF sensor - they fool the ecm into thinking that it's running leaner than it really is... that's bad.. . you'll never get the fueling correct....
and the stock MAF is good for 550+ hp anyway, no need to change it...
so yeah, get rid of the aftermarket MAF sensor and put the stock one back on... THEN you should be much better...
also, if you have a CAI or have done any exhaust work, check everything, all bolts/clamps, make sure everything is TIGHT and no air leaks anywhere...
and no about dslogredux, Grumpy_Aero_Guy gets that, he's the one who actually coded/programmed the application... he'll appreciate it! thanks! ;)
B0nzz
Post by B0nzz »
I didn't say I had an aftermaret one, just wonder if it is a possibility?
I brought the tune back to stock and you were right, it has more power. I ran a data log on the stock tune. How can I tell if it is not a stock tune to start with? I haven't had a chance to hook the pred to my puter yet but by looking over the logs, it looks like the fuel trim is +12...
This is why I hate used cars, you can never tell what was done to them.
I did notice that now that there is no tune, there is no surge between 4 and 8 cyl like when there is a tune. When it was tuned it would surge real bad when the dod turned off..maybe a clue?
post up a copy of your 'stock' tune that the Predator reads out.
B0nzz
Post by B0nzz »
I have attached my "stock" tune and the first one that told me to go -12 on the slope
those are data log files, not your tune file...
read the info/instructions here in SECTION 1 about how to get the original backup stock tune file copied off the predator and to your pc:
http://diablosport.com/index.php?name=P ... pic&t=6547
B0nzz
Post by B0nzz »
I hope this is it!!
yes, that is a stock tune file.... I compared it to other stock tune files, and it's a perfect match...
B0nzz
Post by B0nzz »
Why would be so far off then?
Can something be wrong?
B0nzz
Post by B0nzz »
any ideas?
air / vacuum leaks somewhere?? check the cai, manifolds, exhaust, make sure all bolts/clamps are TIGHT and no air leaks anywhere... check the intake manifold, make sure there's no leaks around that (may have to do a smoke test for that one).... is it still the stock MAF sensor? with the screen still in it?? etc etc
B0nzz
Post by B0nzz »
Its not throwing any codes.
I shot all around the intake and hoses with carb cleaner and no change in the idl what so ever.
Very consistant idle too
Exhust is all welded so no leaks there.
I assume it is stock map but will check it this weekend when I get home
I also just got stomped by a G8.
I ran up along side him around 60 and by the time we hit around 120 he was about three to 4 car lengths ahead of me..is that right? Should a G8 take me?
B0nzz
Post by B0nzz »
It has the stock sesor in it and used another can of carb cleaner around the entire engine.
Any other ideas??
not really... just just be how your car is then... could be your location, elevation/altitude... other than that, if there are no leaks anywhere, then not much you can do about it...
but I would definitely not adjust your injector slope that much... don't go any more than -5% on it...
or get a custom tune done to have the MAF sensor table rescaled appropriately...
smokestack
Post by smokestack »
Since you have a K&N filter i would get a can of maf sensor cleaner and clean it up. Had a issue like that and the oil from the filter had coated the sensor messing up the reading :(
B0nzz
Post by B0nzz »
OK so I stuck my finger in the intake (better then my exhust I guess) and there was a lot of oil carbon build up. Meineke talked me in the fiuel system cleaner and foamed the throttle body and injectors and scrubbed out with a rag and brish for me. They also shot a can of MAF cleaner on my Maf. I pulled all the front plugs and they still look great (got about 30,000 miles on them). I cant even see the rear plugs so I assume they look just as good.
MAF is stock with screen and clean..
OK, time for a customer tune.
06MONTESS, where do I send my money?
I got a amazon $150 GC, will ya take that?
How about AMEX
a goat and a half a six pack?
Let me know.
