no need for an aftermarket MAF sensor - they fool the ecm into thinking that it's running leaner than it really is... that's bad.. . you'll never get the fueling correct....
and the stock MAF is good for 550+ hp anyway, no need to change it...
so yeah, get rid of the aftermarket MAF sensor and put the stock one back on... THEN you should be much better...
also, if you have a CAI or have done any exhaust work, check everything, all bolts/clamps, make sure everything is TIGHT and no air leaks anywhere...
and no about dslogredux, Grumpy_Aero_Guy gets that, he's the one who actually coded/programmed the application... he'll appreciate it! thanks!
