My Diablo Trinity does not have any default guage layouts installed. When I select the "restore Default" option from the Monitoring menu it appears to try to resoter the defaults but there is no change (No gauge layouts are added). I know I can create my own, but if there are some existing gauge layouts I'd like to start there.
Is there some way to restore the default gauge layouts?
Default Gauge Layouts Missing
RE: Default Gauge Layouts Missing
do it from the Logging menu/section... because changes made in the Logging menu/section are what appears in the Monitoring section...
Badjustbad
Re: RE: Default Gauge Layouts Missing
After selectined the Restore Default Gauge Layouts from the Logging menu, it still only shows the (2) gauge layouts I created.06MonteSS wrote:do it from the Logging menu/section... because changes made in the Logging menu/section are what appears in the Monitoring section...
Any other ideas?
RE: Re: RE: Default Gauge Layouts Missing
what vehicle is this?
What vehicle are you selecting?
Badjustbad
Re: RE: Re: RE: Default Gauge Layouts Missing
2011 Silverado 1500 with the 6.2 and automatic trany.mikel wrote:what vehicle is this?
RE: Re: RE: Re: RE: Default Gauge Layouts Missing
lemme check it out...
I had this issue with the CTS-V also with one of the test CROMs. I don't know if it was the newer version that fixed it or if restoring the defaults while it was connected to the computer did.
Badjustbad
I've trying to reset the gauge layouts while connected to the PC (No luck). Previously I had tried resetting the layouts while connected to the truck (Also no luck).
From reading other threads it appears the gauge layouts can be saved to your PC, so I assume there is also a way to load them in from the PC(?). If they can be loaded from the PC it should be a quick fix to send me a file containing the default gauge layouts so maybe I'm just misunderstanding the conversations - wouldn't be the first time.
