SUCCESS!!
white_lightning
Re: RE: Re: RE: Re: SUCCESS!!
Post by white_lightning »
TooCoolHemi wrote:Make's sense, how else would they all know so much about a vehicle bought at a auction but not say. Give the DMV a try or tell them you had the door panel off and found a exspenive diamond inside the door and want to return it.lolololol
good idea Joe! LOL!
speedrules1
Post by speedrules1 »
I wonder if misfire could be bad coil pack??
If its a bad coil, it wouldn't be random. P0300 is a random misfire. P030x is a misfire on a particular cylinder.
Ill_Born_SS
Post by Ill_Born_SS »
When you installed the catch can did you clean your induction system?
" Just Friggin Wicked"
Now with TCM support...
If the truck previously was modded and had a can the manifold shouldn't be too bad......... Unless he's been beating on it. Then he'll have a puddle.
stix518
Post by stix518 »
No, I didn't clean the induction system. Haven't been beating on the truck, either. If I wanted to clean the induction system, what would be the process? (Sorry, semi-mechanically inclined, oil changes and brake jobs mostly).
Stix
2008 Jeep Grand Cherokee SRT8 Automatic
Airaid CAI, BT Catch-Can, Predator Tune
Gotta pull the manifold, open it up and clean it out.
Probably not a bad idea. Then you'll be able to tell if it was ported and you'll be able to tell if the intake runners in the heads were ported.
stix518
Post by stix518 »
Uh, yeah. Like I said, brake jobs and oil changes. Even if I felt comfortable enough to pull the manifold and clean it out, I wouldn't be able to tell if it was ported or starboarded! LOL In any case, hooked up with White Lightning and he's taking excellent care of me! Apparently, there is a cam in this thing!
Stix
white_lightning
Re: SUCCESS!!
stix518 wrote:Uh, yeah. Like I said, brake jobs and oil changes. Even if I felt comfortable enough to pull the manifold and clean it out, I wouldn't be able to tell if it was ported or starboarded! LOL
since the dealer you bought this Jeep from knows it is modded, you could have the intake manifold cleaned there. the mechanics there should be able to tell if the heads & intake are ported.
just make sure they don't do any PCM flashing while your cutom tune is installed. need to tune to stock 1st if they want to do any re-flashing.
stix518 wrote: In any case, hooked up with White Lightning and he's taking excellent care of me! Apparently, there is a cam in this thing!
Stix
glad you like your base tune! should be able to dial the tune in pretty good in a few more revisions.
