trany shifting hard need help
roman1328
Post by roman1328 »
hi i just installed my new diablosport predator u7194 into my 2011 chevy silverado nd i notice that wen ever i would get on it.... the trany would shift really hard for 1st nd 2ed gears..... is that bad for the trany or how could i fix it....
quimbo
Post by quimbo »
I would put the car back to stock first. Then see if the tranny feels or shifts different. From what i know the diablo tune it should not affect the transmission shifting. If the tranny shifts the same after you reinstall the factory back up then i would say it is just a strange coincident
yeah, I know what the issue is... and it can only be fixed by getting a custom tune created... you need to post up here your original backup and last tune written tune files and it can be fixed for you...
BlackZ71Silverado
Post by BlackZ71Silverado »
quimbo wrote:I would put the car back to stock first. Then see if the tranny feels or shifts different. From what i know the diablo tune it should not affect the transmission shifting. If the tranny shifts the same after you reinstall the factory back up then i would say it is just a strange coincident
The shifts ARE firmer with the canned tunes, but it should not "bang".
volk
Post by volk »
i have same concern-- normal to mild accel to 4k is great compared to factory but harder accel when 1-2 shift is 5 -6k there is a delay hesitatation about 2-3 second then a hard shift to 2nd. reinstalled factory backup and there are no shift concerns whatso ever -mild or hard acceleration. besides fuel trims what can be done on the predator- mine is updated to current croms . just installed mpg program with dod turned off. would the pe wot settings help and what would you adjust each of the 3 rpm ranges to....2010 silverado z71 4wd 6spd 5.3 vin 3 motor
JMatthias
Post by JMatthias »
I had the same problem with my 2010 Sierra. Lew fixed the issue when I got my custom tune.
yep... if you don't like it that way, the only way to fix it is to get a custom tune created for the vehicle....
