Which One to Get?
imfletcher
Which One to Get?
Post by imfletcher »
Hello,
I have a 2004.5 Dodge Cummins, will the 2004 Cummins Stack combo work for my truck?
Thank you,
Pat
RE: Which One to Get?
Yes, thats what you need.
reb0957
Post by reb0957 »
MIKEL,
Are you sure? What he means is the engine he has is either the 325hp/600 or 610 ft/lbs. i find it hard to believe you guys would use the same electronics for the 04 305/555 and the 325/610
johan
Post by johan »
Yeah if he has the 325/610 setup which came out in 04.5 he needs to use the 05 puck(which should be released this week, or rather go into production).
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
imfletcher
Yes, I do have the 325hp/600ftlbs engine. so I'm hearing that I need the 05 PowerPuck?
Yes, use part number D7158 Power Puck and the U7130 Predator.
imfletcher
Would the PowerPuck by itself make a good tow module? Since the truck is basically stock, I'm a little apprehensive to get the full stack at this time. Can I add the Predator at a later date if I just get the puck?
Thank you in advance for your time,
Pat
johan
Post by johan »
Yes it will work quite good for towing as it adds good low end torque which you will benefit from.
Diablosport INC
imfletcher
Do you have a date the 05 Pucks will be at thoroughbreddiesel.com?
Thank you,
Pat
