2006 5.9 cummins bad idel
mickey
Post by mickey »
is there a fix to the bad idel with the cummins i installed the 9r07 and still there but now lopeing at idel
2006 dodge ram 3500 5.9 cummins
RE: 2006 5.9 cummins bad idel
try this:
options/troubleshooting/restore original backup, then reload the tune.
mickey
Post by mickey »
did it same problem
leeindy
Post by leeindy »
so its got a bad idel with the factory tune. sounds like a non tune issue
07 Ram Hemi 5.7 quad cab 4x4 big horn. 3.92 gears, Flowmaster exhaust and more coming.
mickey
Post by mickey »
no leeindy it runs fine without the tuner but idels bad with the tuner
ricerocket12s
Post by ricerocket12s »
Iv got a 07 5.9 and have the same issue... I noticed mine does it alot more when its cold out (Below 30*) and when I first start it in the AM.
BEAMING
Post by BEAMING »
Is that what it's called "loping"? Mine sounded like it was was missing and going to die at an idle.
ftwdodge
Post by ftwdodge »
So guys, really when are you going to get this bad idle fixed? This tuner is not worth having if it is not going to work properly!!!!!!
