Hello,
I have a 2004.5 Dodge Cummins, will the 2004 Cummins Stack combo work for my truck?
Thank you,
Pat
Which One to Get?
RE: Which One to Get?
Yes, thats what you need.
MIKEL,
Are you sure? What he means is the engine he has is either the 325hp/600 or 610 ft/lbs. i find it hard to believe you guys would use the same electronics for the 04 305/555 and the 325/610
Yeah if he has the 325/610 setup which came out in 04.5 he needs to use the 05 puck(which should be released this week, or rather go into production).
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
imfletcher
Yes, I do have the 325hp/600ftlbs engine. so I'm hearing that I need the 05 PowerPuck?
Yes, use part number D7158 Power Puck and the U7130 Predator.
imfletcher
Would the PowerPuck by itself make a good tow module? Since the truck is basically stock, I'm a little apprehensive to get the full stack at this time. Can I add the Predator at a later date if I just get the puck?
Thank you in advance for your time,
Pat
Pat
Yes it will work quite good for towing as it adds good low end torque which you will benefit from.
Diablosport INC
Diablosport INC
imfletcher
