Trinity1000 "failed cut" software problem
Pmexpert
Post by Pmexpert »
Used trinity lot of times, but since few weeks I cannot upload or modify any tune(original or custom).
Algorithm:
Performance -> disclaimer(agree button) -> "failed cut" sign
Then pressing continue button and after words "wait a moment" trinity is reloading.
What happens and how could I upload factory tune now?
Alex
First step
First step
Second
Second
Result...
Result...
Third..
Third..
RE: Trinity1000 "failed cut" software problem
is there a tune in the vehicle currently?
yes, he has a custom tune in the vehicle currently, which was done back in June 2011... so, the trinity WAS working fine/ok back then, heh...
Pmexpert
Post by Pmexpert »
Exactly! Custom tune is inside. Last time it was loaded in November to change stock tune that was loaded before getting car to a dealer. Few weeks ago I found that forgot to turn the speed limit off, so decided to use programmer for that and found the problem...
whats the revision?
Pmexpert
Post by Pmexpert »
Just to change iol and oil filter as far as i had 4% oil life remaining.
What revision is the TUNER on? ;)
Pmexpert
Post by Pmexpert »
So the screen capture...
Screen capture
Screen capture
give us a call with it powered up in the car, and we'll attempt to get it to restore.
Pmexpert
Post by Pmexpert »
It's 00:27am here, so only tomorrow morning i can call you being inside the car )) if it is possible, you can pm me detailed instructions or use email for that. If it is not possible, will call you in 7-8 hours.
dude, in 7-8 hours, there will be noone there... this is EASTERN TIME ZONE here in the U.S.
hours are 9am - 6pm eastern time, U.S.... you need to call in those hours..
so, you need to call when it's about 6pm - 3am your time.
Pmexpert
Post by Pmexpert »
Thanks man for your help!)) so will call tomorrow
Return to “Trinity GM Gas”
