Truck Revving and jolting after installed puck
trgoffroader7
Post by trgoffroader7 »
Ive got a 2005 chevy lly duramax. Recently installed the extreme powerpuck had it in a little over a day and seemed to be ok until now. I was driving down the road when my truck started revving around 2200 rpm and being very jolty and the check engine light came on. Turned the truck off and opened the hood everything seemed ok. Started it back up and the check engine light stayed on but ran ok after that. any ideas wat it could be or wat caused the light to come on and my truck do this? I still need to take it somewere to get the code read not sure wat code its throwing.
RE: Truck Revving and jolting after installed puck
sounds like a loose connection possibly.
trgoffroader7
How much pressure is on that shim kit would there be a possibility it maybe come apart i hope not but would the truck even run if that woulda came apart i havent had time to tear anything apart yet or get the code read.
the shim kit sees quite a bit of rail pressure, but they're steel washers, they're not going to break. The bolt is supposed to go back in to I believe 100 ft/lbs, so.....
trgoffroader7
I mean that it actually comes apart or is there something that is touching the other end inside the rail? Like how you have to press the end out with that nut wat if ur crimps would come loose somehow and the spring push the end out of the pressure valve? I think i found the problem anyway but still wondering about that. Started looking at conncections and such found the maf in the intake tube actually popped out and wasnt in the intake tube all the way. Disconnected battery and code went away drove truck and hasnt came back yet.
I would imagine that if the valve was put back together improperly, it could be an issue and cause rail pressure to leak.
