06 Mustang GT auto diablosport tuner 7140
I purchased a kit from RPM Outlet consisting of a diablosport tuner, C&L racer intake kit motoblue underdrive pulleys and twin 62mm BBK throttle body. the tuner came with lokks to be your stock performance tune documentation says it should have tune for Cold air kit from C&L. C&L seems to have a a special diablo tuner.Can you help with a tune
RE: 06 Mustang GT auto diablosport tuner 7140
Under the options menu, select OEM Select.
Choose C&L tunes from this menu, and the tool will now be set up for applying C&L tunes to the PCM.
Go back into the performance tune menu, and it will now contain tunes for C&L performance.
Install the desired tune, and you're all set.
