Diablo Extreme Power Puck Install, truck overheats, no power
dmax39
Post by dmax39 »
Just installed Extreme Power Puck on an 2007 LBZ and once the key is turned on the temp gauge goes to max and overheating message appears on the dash. Truck starts but runs rough, won't go over 1200 RPM's.
2007 GMC 2500HD 6.6L LBZ
dmax39
RE: Diablo Extreme Power Puck Install, truck overheats, no p
Post by dmax39 »
Truck is throwing code P0652
Ill_Born_SS
Post by Ill_Born_SS »
http://www.aboutautomobile.com/TSB/2007 ... cal+Wiring
#4 is likely but the other ones listed can also do it!
could be a loose connector or maybe moisture/corrosion, but it is a known problem.... may have disturbed something with your install.
" Just Friggin Wicked"
Now with TCM support...
yeah, id check for a loose or backwards connector os something, or maybe a connector that didnt get plugged back in?
