2004 6.0 boost surges on 100hp tune
capecodford
Post by capecodford »
u7165
v 9r14
VXBC9QA
I have a 2004 f250 6.0 six speed. With the tune set to the 45hp or 65hp it runs great, worse mileage than stock but definitely more power. With the 100hp tune the turbo really lags and then once it starts to spool up and boost it just surges and falls flat on its face. Any suggestions or new tunes that I could try?
Wes
capecodford
RE: 2004 6.0 boost surges on 100hp tune
Anybody?
can you export a copy of the last tune written and the backup file and post them here?
capecodford
I assume I should load the 100hp tunein before exporting the last written?
if thats the only one that does it, yes.
capecodford
Ok thanks. I'll post it up first thing in the morning.
capecodford
Heres the original and the last written
VXBC9QA.frg
original backup
(214.5 KiB) Downloaded 252 times
VXBC9QA_custom.frg
last written
(28.25 KiB) Downloaded 273 times
Buck02
Post by Buck02 »
capecodford wrote:Heres the original and the last written
So the Tow tune you just sent me is also having a problem Surging? I thought it was just the extreme tune?
capecodford
No the extreme tune is the only one with the issue. I sent you the extreme tune which was the last loaded tune and the other is the original backup file.
the description said Extreme when I opened it.
capecodford
Right. The first one is the last tune written which is the extreme tune. Thats the one in having trouble with. The second one is the original backup file. I was told yo upload them both. I'm a little confused about what you are saying. Do I need to reupload anything?
No, you're fine.
capecodford
Ok thanks any idea what the problem is?
