A few questions about custom tune and cam. Thanks for feedback!
1. Still getting a rolling idle??? sound when cruising like 30-50mph. It sounds like the idle goes up and down in a circular pattern, definiely motor sound--kinda annoying.
Â
2. while sitting at idle if I rev it up, it seems like it takes a long time to return to idle--is that normal?
Â
3. I guess I thought this cam shaft (comp cam 273) would sound more aggressive--don't get me wrong, it responds great especially on the high end, but the sound of idle is nothing at all what I would have thought. Almost sounds stock. Anything to adjust to get that more aggressive sound?
Â
Â
Questions about custom tune/cam on 06 Charger
2010 Dodge Challenger RT (Brilliant Black Crystal PearlCoat)
JBA Headers & Hi-Flow Cats
JBA Cat-Back Exhaust
Mopar Cold Air Intake (w/ functional T/A Hood)
Catch Can, MOBIL1 Oil
Diablo InTune
Satin Black Viper Wheels (staggered F: 20x9 R: 20x10)
Continental Tires (F: 245/45r20 R: 275/40r20)
Diablo InTune
RE: Questions about custom tune/cam on 06 Charger
To clarify below, why am I not noticing more lope sound at idle? Do I need to make an adjustment to the tune?
Diablo InTune
Diablo InTune
What are you idling at? Thats probably why you aren't getting a lope. You aren't trying to run that cam on the stock valve springs are you? If you are they might be floating. Need to run Comp 26918s with that cam.
- Vas@Diablosport
Its all in the tune. Did you have it tuned on a dyno? If so, I would try contacting the tuner and maybe he could make some adjustments to get it where you like it.
No, i don't work here.
Idle was set at 728. I believe comp springs were used and no float was seen.
I'm basically using an email tune for now. I haven't been able to catch up with my tuner but I'll see what he can do. Are there specific adjustments I should run by him?
Diablo InTune
Diablo InTune
check the airflow tables and see what timing is doing during the hunting idle...
