2006 boost surge and high idle issues
stacked06
Post by stacked06 »
i have a 2006 f250 with six speed stick. had my pcm updated the other day. i updated tool. installed extreme tune. truck now will flair up between shifts about 300 rpm also idles at 950 instead of 650. it will come down to 650 if i load the truck up as if i were going to power brake. also the turbo now boosts to over 30 lbs. it goes up to 20lbs then will spike to 30+ lbs. the last time my truck boosted over 30 lbs my oil pump gear blew apart. truck was performing great before pcm flash and tool update. also i had an exhaust brake program for the 9r10 update. i would like to get the exhaust brake program for the 9r14. but one issue at a time.
RE: 2006 boost surge and high idle issues
can you post a copy of the last tune written to your truck, and/or the calid?
stacked06
Post by stacked06 »
here ya go. cal id is vxcf9m4
VXCF9M4_custom.frg
(26.25 KiB) Downloaded 259 times
Buck02
Post by Buck02 »
Send your ori Backup also Please
stacked06
Post by stacked06 »
here it is
VXCF9M4 orig.frg
(225.14 KiB) Downloaded 268 times
Buck02
Post by Buck02 »
Ill look into it today.
Buck02
Post by Buck02 »
Ok there is a High Idle I added for Cold Conditions to help warm the engine up to operation temp sooner under Very Cold conditions. But as the Engine warms up the idle should reduce rpm to normal operations. The flaring between shift may happen if the truck is still cold operation But I havent had this concern before on the new Crom. You should not be seeing that much boost. Is the truck Completly stock no other Engine mods at all? example.... Tuners, boost foolers, intakes, inline modules, rail pressure modules anything?
stacked06
Post by stacked06 »
Just has s&d air filter box. Stacks no cat no muffler. Other then that its stock. Before the updates truck performed with no problems.
Buck02
Post by Buck02 »
stacked06 wrote:Just has s&d air filter box. Stacks no cat no muffler. Other then that its stock. Before the updates truck performed with no problems.
Ok Look for an email Im going to build you a file to test and see if we can get rid of the problem. You did have the trucks CALID updated from the dealer thats why you had to update the tool to latest revision correct?
Buck02
Post by Buck02 »
Check your email i sent you a tune to try and see if that will solve your issues.
stacked06
Post by stacked06 »
yes thats why i updated the tool. i tried to load tune into truck says vin doesnt match my vehicle. do you need my vin?
yes, please email him the VIN.
did you get that error on the DSDL or in the tool at the truck?
