what good is this thing again?
wazmoenaree
Post by wazmoenaree »
Besides causing my ABS to stop working - fixed and Idle surge. What is this thing good for?. It doesn't read trans temp,psi or fault codes. It will reset them which
helped when the thing generated a chek sum freekin error. I hoped to use it to monitor my 2-3 and 3-4 trans glide issue, but it made to many of its own. I did
detect a slight change in power with performance, tow- not!.
It also only lets me change redline/top speed and loosely idle speed with the cruise buttons.
The question is - does it monitor trans temp and psi?
It is possible that my PCM is mental but so far it works better than the sport.
Diablo Sport **625ser on a 2003 stock 3500 5.9L vin C
RE: what good is this thing again?
You should feel the performance gains for sure, if not, i would question if the truck is not healthy.
trans temp is not something the tool can monitor, the tranny uses a separate controller.
