Limp mode on My 06 dodge charger RT
SO i got my new trinity today and updated it, then went out to the car like a kid on Christmas day.. I loaded a 93 CAI tune as i use Sunoco 93 gas in the car and went smooth.. notices that the ESP light was solid and my brake and ABS lights were coming on and off .. as siin as i took off the car went directly into Limp mode. So i stop and turned on dyno mode... well no limp mode and car ran fine.. turned dyno mode off and still in limp mode.. I put the original tune back on and car is fine.. put 91 CAI tune on and again limp mode.. I will look in the forums for more help but i wanted to know if there was any thing quick i can look for.
Please help
John
Please help
John
RE: Limp mode on My 06 dodge charger RT
hmmm...whats the calid and revision on the Trinity?
did you turn off traction control when you loaded the tune? Change tire size?
No tire change, didnt do anything with Traction control
I think i may have found the problem Does the trinity work wth the Jet Performance control module? The person that owned the car before me had this put it.. and i was not aware of it.. I took it out but now it is saying that the trinity is not compatable and gives me the CALID numbers
PCM
05094779AL
TCM
04692392AD
Any Ideas?
PCM
05094779AL
TCM
04692392AD
Any Ideas?
No they don't work together. The Jet is really just a paperweight, but supposedly it changes something so it can't work with another tuner.
Put on the latest version of the software and the newest Incremental update and it should work. Theres no reason why it would work before but won't after removing the Jet.
I am a newb just got this thing today.. so how do i put the latest software on.. Do i download it from this site? Would i need to have my PCM Flashed?
OK so i got the Latest CROM and going through the process again. wish me luck
OK fixed that issue.. had to plug in the Jet and unplug it again and i was able to program and tune the car.. no clue but it worked.. Also set the tire size to the stock winter tires i have on there.. now i have another issue.
ESP/BAS lights up and the ABS and Break lights light up and Ding at me ONLY when the trinity is plugged in. I can program it with the annoying ding and lights it takes the tune then i unplug the trinity and start the car.. no lights and no ding. if i try to drive with the trinity plugged in.. limp mode i cannot get out of first gear. so i have it unplugged and it works great.. but now i am wondering why i bought the trinity when I can only use it like a predator?
Any idea on whats happening.. Why can't i have this plugged in?
Diagnostic comes up with U0121 Unknown
hmmm, something onthe CAN bus is not happy, does your trinity have the plug in the botom or in the back?
On the back.
Are there any logs or test that I can do to find the problem.. if it is with the trinity, cable or the obdII connector, can-bus.
the car takes a tune and I can scan codes. I can modify everything. when it is in the monitoring works and i see the oil pressure rpms and all of that work..
What does the U0121 unknown code mean?
Also is there something I can change to make the MDS not feel so "clunky"
weird, I wonder if it is a bad cable.
i'd love you to fill out the rma request and send it in so we can test it.
Just for the cable or the entire trinity?
Id prefer to test the whole thing.
Ok seeing I bought this un-opened (new in Box) from a member of the LXForums.. I am trying to get a copy of his receipt. would this be an issue if I did not get that receipt?
No, warranty is only good to the original owner....
