Need Help...possible inTune issue? start up idle!
BlackZ71Silverado
Ok here's the problem. Ever since I had my truck (2010 Silverado 5.3L) I had a "canned" DiabloSport tune in it. I was running an Airaid CAI with the 87 Octane tune without issue. I recently switched and installed a Volant CAI, running with same tune. Right after the Volant install I have been having trouble with cold starts. Immediately after start, the truck stubles and spits, almost stalls then will idle up like normal. Now with the Volant kit there was supposed to be a supplied o-ring to use with the MAF, it did not have one so I just left the OEM ring on there. Is it possible that the OEM o-ring is to thick and doesn't allow the MAF to sit in the correct position or doesn't that matter? OR is this an inTune issue I am having? Went over the CAI several times and everything is tight and installed properly.
I posted this on the gm-trucks forum without anyone having a clue, hopefully someone here can help out.
- Ill_Born_SS
RE: Need Help...possible inTune issue? start up idle!
Very simple solution here.... restore the truck to the stock tune and then give it a few days. Does the problem/symptom go away?
" Just Friggin Wicked"
Now with TCM support...
BlackZ71Silverado
I'll have to give that a shot. Was wondering if the o-ring on the MAF sensor had it sitting to high in the tube. The Volant ring is supposed to be thinner allowing it to sit more in the center of the tube. Does it make a difference if the MAF position is slightly off?
2010 Silverado Ext.Cab 5.3L
MBRP exhaust
AirAid MIT AEM filter
Black bear Performance Tuned
2008 Silverado Ext. Cab 6.0L Vortec Max
GMPP exhaust
GMPP CAI
Black Bear Performance Tuned
MBRP exhaust
GMPP exhaust
GMPP CAI
- Ill_Born_SS
clocking the MAF is important as the airflow must pass over the sensor without turbulance/flutter. There should be a keyway /slot on the MAF itself and on the original ducting... you should be able to eyeball it as to where it should sit properly. Oil in/on the MAF and/or an over oiled filter can also cause these symptoms. Use CRC sensor clean to clean the inside of the MAF if there is any oily residue.
Have you logged and dialed in your tune yet? If not wait until you solve this problem first.
BlackZ71Silverado
Thanks for the info, very helpful!
MBRP exhaust
GMPP exhaust
GMPP CAI
MBRP exhaust
GMPP exhaust
GMPP CAI
He has a drop in MAF instead of the whole unit being part of the intake tube. It only goes in a slot on the side of the tube. I would go back to stock and recheck the install and see if the problem goes away, I have a K&N Aircharger and had no problems on the 87 tune.
2010 GMC Sierra 5.3
K&N Aircharger
Blastin' Bob Muffler-back with Magnaflow
Diablo Sport inTune, Diablew tuned
K&N Aircharger
and yes the 0-ring makes a difference with those intakes as far as how it seals up... have seen it before...
better find that o-ring...
BlackZ71Silverado
Re: RE: Need Help...possible inTune issue? start up idle!
Appreciate it thanks a lot, I appreciate the information........sent email to their customer service about it with no response, going to call and find out. It did not come with the kit. In the mean time, going to try different o-rings to see which one makes the problem go away.06MonteSS wrote:and yes the 0-ring makes a difference with those intakes as far as how it seals up... have seen it before...
RE: Re: RE: Need Help...possible inTune issue? start up idle
I think my Volant on the 03 SS used the stock throttle body, it's been a though.
2010 GMC Sierra 5.3
K&N Aircharger
K&N Aircharger
BlackZ71Silverado
Re: RE: Re: RE: Need Help...possible inTune issue? start up
The issue is NOT with the throttle body. It is with the 0-ring that seals the MAF into the hole. Volant is supposed to supply the correct one with the kit and they did not. My OEM MAF o-ring seems to be to thick, causing a start up problem and truck runs like crap.rdss wrote:I think my Volant on the 03 SS used the stock throttle body, it's been a though.
RE: Re: RE: Re: RE: Need Help...possible inTune issue? start
Ah, got you. Good luck getting one that will work for you!
2010 GMC Sierra 5.3
K&N Aircharger
K&N Aircharger
- Oldsaltydog
No of fence but it goes in one way only should have an arrow on it pointing towards the air flow path. My does and it just drops in the hole.
Oldsaltydog
2007 corvette c6
2007 corvette c6
BlackZ71Silverado
Re: RE: Re: RE: Re: RE: Need Help...possible inTune issue? s
Yeah, it's about impossible to install it the wrong way. The electrical connection is not long enough to allow it to be installed backwards, no way you would be able to get it plugged in.Oldsaltydog wrote:No of fence but it goes in one way only should have an arrow on it pointing towards the air flow path. My does and it just drops in the hole.
When it was in my Airain CAI it dropped right in. When I switched over to the Volant, it was a really snug fit because of the OEM o-ring being bigger than the one Volant is supposed to send....It would be much easier if they would just make an adjustment to the intake tube to allow for the regular o-ring to be used. Sounds more practical to me.
Did your Volant CAI come with a replacement/different sized o-ring?
Last edited by BlackZ71Silverado on Wed Feb 08, 2012 3:18 am, edited 1 time in total.
BlackZ71Silverado
I know this is a long shot but would you happen to know the actual size of the correct o-ring?06MonteSS wrote:and yes the 0-ring makes a difference with those intakes as far as how it seals up... have seen it before...
I have been trying to deal with Volant customer service and they keep telling me "disconnect the battery", they don't understand that it was done before install and is not going to fix this problem. They also keep telling me that the o-ring "should have been in the box", which it wasn't and that's why I have this probelm. When I asked them the o-ring size, I was told thinner than stock and they could not give me a diameter or thickness.
EDIT : PROBLEM SOLVED
in case this happens to anyone else, the proper o-ring size is #57
1"x 13/16 x 3/32
