'05 GC won't hit 5th gear/lockup until 75mph..??
The trans tune you posted had considerable changes done to the lockup logic, all i did in the attached tune here was set that back to stock, everything else was left as is.
This was the custom cmr tune you posted right?
- tcm_ltw_001.drg
- (119.22 KiB) Downloaded 175 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
but did you get any custom tunes from any CMR tuners?ksrracer wrote:This happened on every tune loaded since I received the intune. Like I said it never happened when set back to completely stock or when the Superchips flashpaq was loaded.
Yes. That was the last tune written. As I posted earlier this happens on the canned tunes, the CMR, and with the stock trans tune on the Intune. It does not happen when the intune is removed completely and or I'm running the Superchips. It has lead me to believe its something with the Intune itself.johan wrote:The trans tune you posted had considerable changes done to the lockup logic, all i did in the attached tune here was set that back to stock, everything else was left as is.
Why would it not hit 5th until 75+MPH and then when 0% throttle load and coasting down, it will downshift into 4th around 68mph?
ok, bu the changes in your tune were not something we do, and would cause your issue, so can you load the canned tune, reset parameters, and export that so we can see it.
well I cant fix it if we cant see it.
please do so if you can.
the preloaded tcm perf tune
Yes, thats correct.
Mikel here is the canned 91 tune and perf. tcm tune LTW.
- PCM_LTW.drg
- (36.63 KiB) Downloaded 166 times
- TCM_LTW.drg
- (125.38 KiB) Downloaded 172 times
- white_lightning
Johan, retracting post, did not mean to cause trouble. I apologize.
hope this Jeep's issue can be fixed easily.
Last edited by white_lightning on Wed Feb 15, 2012 5:57 pm, edited 2 times in total.
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
My Ride:
We only write calibration data, so there cant be changes outside the tune data.
The last tune written from an inTune is an actual copy of what was written to the TCM, so you can see exactly what went in.
We are investigating.
