upload 2 Custom tunes on tool U7137 HELP
adventurer
Post by adventurer »
I have 2 custom tunes, when i want to upload them to the tool ( U7137) i can only upload one tune then if i want to upload the second one it overwrites the first tune and i end up with only one custom tune on the tool ! how can i upload the 2 tunes ? and can i change the label name (pcm_00000000ak_per.drg) to another name like (pcm_custom_2.drg) ?
PS : Original first tune name pcm_00000000ak_perf_002.drg and the second tune name pcm_00000000ak_perf_003.drg
( 1 ) 2010 RAM HEMI CC/ S&B CAI/87MM TB/JET 180 TSTAT/HKS TB GW/OIL BREATHER FILTER/Y PIPE/PYPES VIOLATOR MUFFLER/DS CUSTOM TUNE.
( 2 ) 06 Ram QC hemi 4x4 SLT, Sport , Magnaflow cat-back ,Y pipe , Poweraid TB spacer, HKS TB GW, SRT8 Mopar CAI, DS Custom tune, Oil breather filter, Jet 180 Tstat.
LeHemi
RE: upload 2 Custom tunes on tool U7137 HELP
Post by LeHemi »
I have the same problem.
adventurer
Re: RE: upload 2 Custom tunes on tool U7137 HELP
LeHemi wrote:I have the same problem.
I hope that some one will solve our problem , because its a headache when i want to use another custom tune , i have to install one of the canned tunes on the truck then delete the custom tune on the tool then upload the one i want to use then download it to the truck and so on ,,,,,,,,,,
frenchbee2306
Post by frenchbee2306 »
same stuff for me
can't reload both PCM 93 oct perf modified tune and TCM perf trans tune modified into the truck
tried from SDcard and from DSDL.....that don't work
'09 Dodge Challenger SRT8 6,1L Hemi / '06 Chrysler 300C SRT8 6,1L Hemi
adventurer
yes it gos for both custom PCM & TCM
In DS Downloader, you need to go to Advanced and make sure to give them different names, like Tune 1 and Tune 2 or whatever they're for. If the names are the same (not the filename) then it will overwrite.
adventurer
Mike_Levy wrote:In DS Downloader, you need to go to Advanced and make sure to give them different names, like Tune 1 and Tune 2 or whatever they're for. If the names are the same (not the filename) then it will overwrite.
You mean i change the label name like pcm_tune 1.drg by changing the file name before i open the DSD ? coz only i can change the description on DSD
No, open DSD and go to the Advanced tab. Change the name there.
adventurer
Mike_Levy wrote:No, open DSD and go to the Advanced tab. Change the name there.
Ok got it, but do i have to keep the .drg after the name ? and can i delete the pcm letters? ex: pcm_00000000ak_001.drg can it be Tune 1.drg or tune 1 ?
and can i also change the description too ?
You can change everything. You don't need the drg. It knows what the file is.
adventurer
Mike_Levy wrote:You can change everything. You don't need the drg. It knows what the file is.
OK i ll try it , THANKS FOR UR HELP MIKE
LeHemi
Post by LeHemi »
Well I tried changing everything I could and also loading 3 modified tunes at once and one at a time and it still only loads 1 tune.
adventurer
LeHemi wrote:Well I tried changing everything I could and also loading 3 modified tunes at once and one at a time and it still only loads 1 tune.
oppsssss , i renamed the tunes and uploaded them to the tool but i didn't plug it to my truck to see if it work or not BUT if u tried it and didn't work maybe it will not work with me coz we have the same problem , anyway tomorrow i ll try it coz now its midnight here and its freezing outside, i will give feedback tomorrow
DID YOU CHANGE THE LABEL AND THE DESCRIPTION ?
LeHemi
Post by LeHemi »
Yes, but maybe I did not do it correctly.
It won't work if you load them one at a time. You gotta load them all at once.
