7135 with R18 worked on first new log then started crashing
sweetsrt8
Post by sweetsrt8 »
I updated to the new R18 and created a new log that worked. However I created another log following day with just timing and Rpm and Knock ST/Lt and the dataviewer crashes just like when R17 was installed. Any help?
johnc
RE: 7135 with R18 worked on first new log then started crash
Post by johnc »
I just recorded and downloaded a log just fine from a 300 SRT8, using R18 and those exact same PIDs. Please repeat the crash and email me any runtime.txt file and download.log file that you find in the same directory that you installed the DataViewer to.
johnc <at> diablosport.com
sweetsrt8
Post by sweetsrt8 »
Sorry I didn't list all my PID's.
RPM
1/1 LTadap
2/2 Lt adap
Knk Lt Retard
Knk St Retard
pdl_pos_%
Spk_Cyl1-8
I will attach the runtime.log next
sweetsrt8
Post by sweetsrt8 »
I tried to attach the files to my post but I keep getting error about me trying post an empty file. I know the files are not empty, I can open them on my PC?
sweetsrt8
Post by sweetsrt8 »
One thing odd I did notice is looking back at handheld recorded log, my 2/1 LT Adap at several times reads out 12797.27 and 1/1 Lt adap is 1.17. That value can't be real can it?
johnc
Post by johnc »
The file attachment feature of this forum doesn't work. Just attach the files to an email - my address is in my signature below.
sweetsrt8
Post by sweetsrt8 »
Done! Thanks for the help!
johnc
Post by johnc »
Email received. That log file has the same issue from R17 that was (supposedly) fixed in R18. Would you verify for me that your Predator says R18 above the main menu? And this log was definitely recorded after the CROM update was completed? Sorry to double check, but I want to be sure before I go cause trouble for someone.
sweetsrt8
Post by sweetsrt8 »
Yes sir, I see Predator v.8r18 on the hand held menu. And yes I had recorded it after applying the r18. I did another run last night and tried to use the dataviewer with a new log and it crashed again. Do you want the log files from that run? Thanks for the support guys!
johnc
Post by johnc »
No, what I have should be enough. Thanks Brady.
johnc
Post by johnc »
Try this new release:
DataViewer 3.1.5.4
I implemented a workaround for the broken log files.
sweetsrt8
Post by sweetsrt8 »
Excellent! I'll try it now and let you know. Thanks again for the help!
sweetsrt8
Post by sweetsrt8 »
Seems to be working fine with that release! Thanks a bunch!
johnc
Post by johnc »
Sure thing. Sorry about that issue.
Return to “DataViewer”
