2007 nbs silverado ABS lights
48fleetline65
Post by 48fleetline65 »
I have a 2007 silverado nbs u7194 9r10 I tried to install 87 octane tune and the abs lights come on within 5 minutes driving. I see this is a common problem. I have read the forum and tried to change aspect ratio and speed limiter to 120 with no luck. Here is my original backup and last tune.
614088616011 original backup.grg
(54.84 KiB) Downloaded 200 times
614088616011_custom.grg
(2.25 KiB) Downloaded 196 times
Dustinbyczynski
RE: 2007 nbs silverado ABS lights
Post by Dustinbyczynski »
i have had the same issue on my 07 nbs for over a month now i sent them copies of my backup and custom tune also still waiting for a fix they sent me one file that did not work either and that was feb 23rd . Still no response since . good luck to ya it has taken at least 2 weeks to get response each time
Re: 2007 nbs silverado ABS lights
48fleetline65 wrote:I have a 2007 silverado nbs u7194 9r10 I tried to install 87 octane tune and the abs lights come on within 5 minutes driving. I see this is a common problem. I have read the forum and tried to change aspect ratio and speed limiter to 120 with no luck. Here is my original backup and last tune.
that is a very old revision, please restore the stock tune and update the tool and try it again.
48fleetline65
RE: Re: 2007 nbs silverado ABS lights
I have an "older" 7194 after reading on here mine will not accept anything after 9r10. I read that you should update with 9r19 first and then 9r29. the 9r19 update would not work. any way of upgrading mine?
nope... could sell it... could trade it in to diablo and get a new version 7194 predator for 250... or, trade it in towards a Trinity and get a trinity for 500...
trinity would be the better choice, since it has tcm/tranny support and more features... the predator doesn't, and never will....
48fleetline65
Monte after researching on this forum I have seen some other "fixed tunes" for a 2007 nbs the numbers (614088616011) at the top of the download match mine. I presume that is the ECU part#. would I have any luck trying that download? without frying my ECU
gotta link to that so I can see what you found?
48fleetline65
2007 abs lights
Thanks for your help Monte
pcm_614088616011_87_octane_tune_modified_001_dod_200.grg
(46.87 KiB) Downloaded 197 times
RE: 2007 abs lights
update to fix this will be done this week.
48fleetline65
RE: 2007 abs lights
any luck??
RE: 2007 abs lights
there were a few thousand tunes to redo, yesterday he was down to 200 left, should be really soon :)
Re: RE: 2007 abs lights
48fleetline65 wrote:any luck??
Here we go guys, this should be the fix :)
u7194-9t30g.crom
(1.71 MiB) Downloaded 187 times
48fleetline65
RE: Re: RE: 2007 abs lights
Just tried to update tool the screen says incompatibale hardware??
Re: RE: Re: RE: 2007 abs lights
48fleetline65 wrote:Just tried to update tool the screen says incompatible hardware??
that means you have a very old tool.
Export the backup and Last tune written and we'll fix it for you in a custom tune.
RE: Re: RE: Re: RE: 2007 abs lights
mike, 48fleetline has his files already posted/attached in his first post at the top... ;)
Return to “Predator GM Gas”
