It is updated to the latest releases.
Intune freezez when I press Write Vehicle ( Jeep TJ 2006 )
I Tried to connect my Intune to my jeep wrangler sport 2006, when i make press write vehicle it freezes as below pictures, everything else is working properly like DTC & Data Logging . Called Diablo Sport, made a reset for the intune,( coasted me around 15$, because am calling from Amman Jordan ), and it still freezes
- Firmware Info
- IMAG0025.jpg (472.04 KiB) Viewed 4016 times
- Tool Status
- IMAG0026.jpg (398.45 KiB) Viewed 4016 times
- Vehicle Info
- IMAG0027.jpg (413.1 KiB) Viewed 4016 times
- IMAG0028.jpg (504.41 KiB) Viewed 4016 times
- It freezes right here when I press Write vehicle :(
- IMAG0029.jpg (290.76 KiB) Viewed 4016 times
RE: Intune freezez when I press Write Vehicle ( Jeep TJ 2006
Here is my xml from my intune as well.
<?xml version="1.0"?>
-<tool_info> <main svn="3753" sw_rev="1r01d" full_version="InTune-1r01d 01/11/2012 11:05:00 AM"/> <registration status="0" sn="CIB3YED-1"/> <restore bc="0" vin="1J4FA49S46P738400" id="0"/> <db pid="1r01a" tune="1r01c" mfr="GM"/> <db pid="1r01a" tune="1r01a" mfr="DCX"/> <db mfr="FORD"/> <system_db vin="1r01a" info="1r01a" dtc="1r01a"/> <license tuned="0" avail="1"/> </tool_info>
Just call.the tech line and they'll hook u up. I think a lot of dodge and Chrysler owners are having this problem. I did with my ram. Just call and they'll walk u through it.
I called them and made a reset, what did they do with you when you called them ??!!!
Anyoneeeeeee ???????!!!!!!!!!!!
Helllloooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
They should of reset your device if you called them. You'll have to get back on a pc and reupdate the itune, then try it out. Thats what I did and it worked for me.
I did that, called them and made a reset then updated my intune. but still the same probem
Diablo Sport Team,
Is my CALIBRATION ID supported for the intune ??? ( Calid : 56044704AE )
Vin# : 1J4FA49S46P738400
I appreciate if you reply.
Please try calling again, we would like to try to help.
I called yesterday, made a reset for my intune, and Vas sent me a file on my email and IT WORKED
At Last.
Thank You DiabloSprot team for resolving my issue
Heno, glad they took care of you in a timely fashion! How's the TJ driving now?
2010 GMC Sierra 5.3
K&N Aircharger
Blastin' Bob Muffler-back with Magnaflow
Diablo Sport inTune, Diablew tuned
K&N Aircharger
It's more active, definitely better than stock. I am trying the 87 octane tune but Still checking if I have more mpg. But I can't adjust my 31 inches on it, its not supported. And I can't find the COT option to turn it off.
there is no COT for dodge applications...did you remove the cats?
If tire size is not working, please go to settings/tool info/vehicle info and tell me what the calid is.
Yes Mike i did remove the cats and I installed K&N Round Tapered (Cone) filter on the stock air intake pipe, the cats were blocked long time ago and the mechanic recommended the Predator for me.
My Calid : 56044704AE
ok, we're checking it out.
