Hey guys, great product first of all, it really tied everything together.
2007 Mustang GT, 5 speed stick
Airaid Cold Air intake
poweraid throttle body spacer.
my fuel efficiency was better after i ran the tune and had the cold air intake installed. i was getting roughly 23 on the streets and 27 on the highway, i dont know how, but im not complaining.
I just added a borla exhaust this weekend, its a straight flow through design with perforations in the inner tube. I have gained a little bit of power, but i have lost my fuel efficiency. it has dropped to 17 on the streets and about 22 on the highway.
im wondering if this extra flow in the exhaust is making the MAF read more airflow and dumping more fuel into the engine. how can i compensate for this modification and save myself some pennies at the pump, cause im already using 91 octane because of the tune.
I wouldnt mind the excessive use of fuel at wide open throttle, but dealing with my commute, i want to remain as efficient as possible.
Any help would be great. Thanks!
Fuel Consumption
acascianelli
RE: Fuel Consumption
Axle back mufflers will have very little to no impact on the performance of the your car. My guess is your fuel economy hasn't changed at all, probably just your driving habits recently.
2007 Mustang GT
Steeda CMCV Delete Plates
Steeda Underdrive Pulley
Bamachips Race Tune
Sequential Tail Lights
Hurst Short Shifter
Pypes O/R X-pipe
C&L Racer Intake
Bamachips Race Tune
Hurst Short Shifter
Pypes O/R X-pipe
C&L Racer Intake
fordfan1964
i went out and tore around for a bit after getting everything on to test it out, but then getting back into the gentle driving of california highways and backroads, i can significantly notice a large drop in fuel efficiency!
Pull the battery cables and touch them together.
Re-connect and go, this will reset your learned fuel consumption, and the mileage readout should go up.
Dont pay too much attention to those readouts either, as they are often off by quite a bit.
Log the actual mileage against a full tank of gas to see what you are actually getting.
fordfan1964
i'll try that. hopefully it works. i already tried turning off the O2 sensors to see if that would change anything.
Thanks!
Thanks!
If you still have cats turn the rear o2's back on....
Phil Jones
Diablosport Inc.
Tech Support
Please do not PM us for tech support, post up first!!!
Diablosport Inc.
Tech Support
