2010 6.4L Powerstroke high idle
I have a 2010 F250 and I have recently done the DPF/CAT delete and an EGR delete kit. After doing all this to my truck it now idles at about 1000rpm and 1200 when its cold. I am looking into purchasing a diablo sport predator for my truck but was wondering if this programmer will send a code that will idle my truck back down. Any assistance will be very appreciative!
RE: 2010 6.4L Powerstroke high idle
Hmmm...do you have any trouble codes present currently/
What means are you using to delete the dpf and EGR?
tech@diablosport.com
- Ill_Born_SS
Did you use any type of device to change the programming after the hardware removal?
" Just Friggin Wicked"
Now with TCM support...
- Ill_Born_SS
I have a guy here using the DPFr 4.0 and the extreem puck and the Trinity together and no problems other than rolling sheets of rubber off the tires. No EGR delete yet though. I willl see if I can reach him about wether or not he can modify the idle.
- Ill_Born_SS
Cannot reach him at the moment...will try again later when he is back from work!
Maybe Mike can answer if there is an idle adjustment on the unit.
If you can find the coin ...The Trinity is the way to go! Engine and tranny tunes that are Wicked.
Nope, same tunes as the trinityadhaynes91 wrote:is there any downfalls to the predator?
no, there are no idle speed adjustment options...but your tune has not changed, so it is still commanding a stock idle, if it is higher something else is affecting it.
My guess is that even if you told the PCM to lower the idle, you'd still have the issue since it seems to not have control of idle speed currently.
gotta determine the cause to get the fix first...
- Ill_Born_SS
Have you rechecked all the wiring connectors in the area worked on, the coolant temp sensor could cause it if there is no reading (cold) is what the computer will see and put in high idle.
Could try contacting GeraBoxZ they may have encountered it.
