Where is the transmission adjustments?????
got a predator u7137 version 9r13 and cant seem to find the trans adjustments. Thanks in advance
- adventurer
Re: Where is the transmission adjustments?????
after you select the tune you wish to load, select 'modify tune' then go to modify parameters then select transmission , good luck05ram2500 wrote:got a predator u7137 version 9r13 and cant seem to find the trans adjustments. Thanks in advance
( 1 ) 2010 RAM HEMI CC/ S&B CAI/87MM TB/JET 180 TSTAT/HKS TB GW/OIL BREATHER FILTER/Y PIPE/PYPES VIOLATOR MUFFLER/DS CUSTOM TUNE.
( 2 ) 06 Ram QC hemi 4x4 SLT, Sport , Magnaflow cat-back ,Y pipe , Poweraid TB spacer, HKS TB GW, SRT8 Mopar CAI, DS Custom tune, Oil breather filter, Jet 180 Tstat.
RE: Re: Where is the transmission adjustments?????
It doesn't give me a option for transmission.
TooCoolHemi
Noticed you have a 2500, not sure what tranny they come with. Is your tranny a 545rfe?
Couldn't tell you what trans is in it but when I installed the tune it asked me if I wanted performance trans tune, I selected yes then I go back to modify parameters and it has no trans selection. The tuner is reading the tcm and pcm and I get calid for both the tcm and pcm just no adjustments.
