7135 with R18 worked on first new log then started crashing
I updated to the new R18 and created a new log that worked. However I created another log following day with just timing and Rpm and Knock ST/Lt and the dataviewer crashes just like when R17 was installed. Any help?
RE: 7135 with R18 worked on first new log then started crash
I just recorded and downloaded a log just fine from a 300 SRT8, using R18 and those exact same PIDs. Please repeat the crash and email me any runtime.txt file and download.log file that you find in the same directory that you installed the DataViewer to.
johnc <at> diablosport.com
Email received. That log file has the same issue from R17 that was (supposedly) fixed in R18. Would you verify for me that your Predator says R18 above the main menu? And this log was definitely recorded after the CROM update was completed? Sorry to double check, but I want to be sure before I go cause trouble for someone.
