inTune freezing when writing
hulkster
Post by hulkster »
When attempting to write to the vehicle for the first time, inTune froze. I called support and had it reset. I updated the files and attempted to write again. inTune froze again. I was informed by technical support that an issue existed on the server when sending out calibration updates. I'm checking back to see if the issue has been resolved and if I can begin to the process.
Thanks.
RE: inTune freezing when writing
is your tool on the 1r01e version?
hulkster
Post by hulkster »
Yes, sir. Under "Firmware Info," I read "Application: 1r01e."
JonDiablosport
Post by JonDiablosport »
if the tool is not in recovery mode please connect it to a computer and allow it to download 1r01f
Diablosport Tech support
p: 561-908-0040
F: 561-908-0048
hulkster
Post by hulkster »
Thanks for the response. Application now reads 1r01f. Unfortunately, inTune still freezes when I connect to the car (2007 Charger SRT8, CAI, exhaust system).
Hmmm
it likely just needs to be reset. We'll sorry it out Monday morning for you.
GOTAHEMI
Post by GOTAHEMI »
My car won't start...Intune stuck in recovery mode!! HELP
2006 Charger RT, MOPAR CAI, SRT udp,SRT timing set, SRT headers, mid-pipes w/ Borla CAT BACK, 300 SRT 20's powder coated black, R1 SLOTTED rotors, SRT suspension
Re: RE: inTune freezing when writing
GOTAHEMI wrote:My car won't start...Intune stuck in recovery mode!! HELP
plug the tool into a PC. When it asks if you want to restore stock tune choose no.
intune will go back to main menu. From there let it auto update.
After it updates go to the car and let it restore stock tune.
GOTAHEMI
RE: Re: RE: inTune freezing when writing
Post by GOTAHEMI »
mikel, i really appreciate the fast response.
Ok i have done all that an now when i drive my ESP / BAS light comes on? why?
Tough to say.
If you are up and running now, lets hold off and look into that on Monday.
Maybe try disconnecting the battery for a minute or two (both cables) and see if that gets rid of the lights.
GOTAHEMI
Post by GOTAHEMI »
It also said no ECU found check ignition?
mrGlass311
Post by mrGlass311 »
I have a similar situation. My 08 Silverado will not start (in recovery mode, won't write factory backup) When I called tech support Friday. A Frank sent me a "cd-rom1r01d.itf" file. I am not sure what to do with it... I think because it was close to quitting time, I was rushed off the phone. Any help?
mrGlass311
Sorry the actual filename is "cdrom-1r01d.itf".
GOTAHEMI
Re: RE: Re: RE: inTune freezing when writing
Post by GOTAHEMI »
mrGlass311 wrote:I have a similar situation. My 08 Silverado will not start (in recovery mode, won't write factory backup) When I called tech support Friday. A Frank sent me a "cd-rom1r01d.itf" file. I am not sure what to do with it... I think because it was close to quitting time, I was rushed off the phone. Any help?
I went an manually searched for update...once intune updated all was fine besides my ESP AND BAS lights wouldn't go off, but in my book it told me to turn the wheels all the way to the left and then right. I did that and soon as i got up to speed they went off.
Hope this helps.
if you are still having issues please give us a call with the tool powered up inthe car.
