2008 JEEP SRT8 - ISSUE - Backup PCM
INTUNE i-1000
2008 JEEP SRT-8
I just received the InTune i-1000. I updated the devices correctly. I then continued to update the truck with InTune. Following the prompts on the device I select one of the available tunes for my vehicle. The device starts to backup the factory PCM. I then hear a electric sound and snapping from under the hood. The devices reading backup 0% next the dashboard ABS starts blinking and battery light kicks on. then I chimes for check engine light and status screen reads 4wd needs services... check gauges... Device reads unable to backup PCM. Goes back to main menu.
Reluctantly, I proceed to attempt the procedure a few more times with the same results.
Prior to running the InTune device on my truck I have had 0 issues with my vehicle. Don't know if that is going to change now after attempting to update with a Diablo tune. I will be reaching out to support later today.
2008 JEEP SRT-8
RE: 2008 JEEP SRT8 - ISSUE - Backup PCM
Yes, please give us a call, sounds like there is a communication issue in the truck.
Any aftermarket electronics inthe vehicle?
I am emailing you a file and some instructions...is the tool still stuck trying to restore the calibration update?miket93 wrote:Diablo support told me the this morning. I wasnt expecting the dashboard to light up like it did.
However, The PCM backup does not complete. The tune never gets started.
Ok, re-read this, the tool is not in recovery mode, right?
It boots up to the main menu, but simply willl not save the stock tune?
email sent.
awesome, enjoy!
I am having this same issue after tech got me reset from the freezing up part. goes all the way until it won't write the back up just like this guy was having. No electronics added outside of factory just got home from work 35 mile trip so the battery is up. mine is an 09 dodge and I have owned it since 7 miles.
09 Dodge Ram Hemi Ram box Rocks
11 blackberry Durango awsome collor
