u7194 2007 NBS GMC Sierra
devilish1500
after recalibrating for my tire size my "brake" and "abs" lights are on on my dash. tried both methods of resizing. how do i turn them off and keep abs?
RE: u7194 2007 NBS GMC Sierra
These new ABS modules are very ensitive to actual tire size. The numbers listed on the side of the tire are often way off.
The best advice would be to go to the tire manufacturers website and see if they list actual sizes for the tires you are running.
Use these measurements to fine tune the tire size input to the Predator and the lights should go out.
devilish1500
tires are pro comp xterrain 35x12.5r18 site shows actual as 34.8 dia and 12.5 width
my diablo is set to 317x62r18 or 33.5x 12.5r18 to make the speedo right
soooo if i set to 34.8 it'll be wrong speed, i had it set to 35, 34, and 33 at differnt points to tune the speedo and sensor was on at every one but fine when the computer had the factory tune in it and running the 35 tires (diameter enter mode)
So, you have verified the speedo to be correct with a GPS then?
The best suggestion I could make is to alter the aspect ratio from '62' to a slightly larger or smaller value to get everything working together.
devilish1500
devilish1500
devilish1500
devilish1500
We made a new update, it is on the web.
devilish1500
ok, downloaded the update when it came out. have changed the ratio up and down, width up and down and still cant get the lights out. again the reason i got the tuner was to fix my tire size. a few friends got hypertech tuners an just typed in 35" and it works perfect. whats next? i want my speedo fixed or a refund to get a tuner i can get to work
Hey Devilish sorry to hear your still having problems Did you try the settings I gave you over at CTW?? I dont see them in the thread so ill repeat them for you .... for a tire 12.5 x 34.8 x 18 use 317/67/18 for 12.5x35x18 try 317/68/18 Im pretty sure you have to enter the info into the predator in the metric sizes to get it to work .
Have you tried resetting all parameters, and then re-entering the tire size?
devilish1500
