Downloader issue
CrazyKZ
Downloader issue
Post by CrazyKZ »
I had been using the downloader program and installed my tune weeks ago. Now I want to install an updated crom and when I try to open the program it gets the area where I click on update (or anything else) and the program dies and goes away. Tried rebooting and uninstalling and re-installing too.
I am using Windows Vista.
Thanks!
RE: Downloader issue
Right click, go to Properties, Compatibility and run it in XP Mode
CrazyKZ
Post by CrazyKZ »
That's actually where it was. I tried with and without that and both times, it does open, waits a few seconds and just goes away...
any other programs running?
CrazyKZ
Post by CrazyKZ »
Nothing else really running. Clean reboot.
weird...thats a new one.
Got a different PC you can try it on?
CrazyKZ
Post by CrazyKZ »
Ahh, I think it was my AV software killing it for some reason. Opened it and it stayed open at least this time. :)
Also, I have the 9r12 installed. What's the preferred order for updating? Use tuner to go back to factory, then install new crom, then update car? Do I need to drive it in factory mode for awhile first? Read on your site that if I update without going back to factory that it will wipe out my factory setting?
yes, restore, update, retune.
Nothing more is needed.
CrazyKZ
Post by CrazyKZ »
Snap. Tried to upgrade from 9r12 to 9r29 (9r30 I know from earlier didn't work), but my tool still says incompatible hardware. :( This tool must really be old. Might be time to sell and upgrade.
Was hoping too to at least adjust the fans since I have a 180 thermostat now. The only adjustments I saw on mine was ESP, tire size and transmission. Am I looking in the right area? I went through each option.
Fans are not in the Quick Adjust. When you go to install a tune you'll see a selection to Modify Tune. Thats where you change the fans.
CrazyKZ
Post by CrazyKZ »
Oh, I see. That's good. Now that I already have the tune installed, do I need to go back to stock again, then reinstall a tune with adjustments or can i just modify the tune still?
Nah, just you can just reinstall it with the changes. No need to go back to stock.
CrazyKZ
Post by CrazyKZ »
Thanks. Done (went to stock again anyway). :) Will test drive tomorrow.
Thanks for your help!!
CrazyKZ
Post by CrazyKZ »
Drove great today. Temp stayed right on target all day. :)
