2009 pontiac g8 gt speed limiter
Was just browsing and seen this post,. I posted a little while back on the same thing http://www.diablosport.com/index.php?na ... ic&t=32761 , just wondering if anything changed since Ive got sent the last tune to try, I havent got a chance to drive the car yet to see if the limiter is off yet,.. If you did figure something different out the last tunes are in that last post to modifiy thanks
if you need it disabled, the fix will be inthe next update or you can post your tunes now and we'll do it for you.
here they are, Thanks Again
- pcm_624402225620_geralddugree_diablew_tune_5_124.grg
- last tune written
- (50.76 KiB) Downloaded 197 times
- PCM_624402225620.grg
- original tune
- (59.38 KiB) Downloaded 223 times
here you go
- pcm_624402225620_geralddugree_diablew_tune_5_001.grg
- (50.75 KiB) Downloaded 201 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
no, you can't uses someone elses tune file.. it's tied/locked to that specific vehicle's VIN number and engine calibration ID's...
