inTune freezing when writing
RE: Re: RE: Re: RE: inTune freezing when writing
hey Mike, I am all back normal, do you know why it froze up? I have used it before and never had any issues until i needed to restore.
2006 Charger RT, MOPAR CAI, SRT udp,SRT timing set, SRT headers, mid-pipes w/ Borla CAT BACK, 300 SRT 20's powder coated black, R1 SLOTTED rotors, SRT suspension
it was a bug in 1r01e.
hulkster
Update: With TS support in resetting the inTune (clearing everything and getting a new code), I was able to get past the original freeze and inTune was able to read and store the stock PCM. When attempting to install a new tune (CAI 91), I get the following error when inTune is attempting to backup the original PCM: "Failed to read PCM Original Backup." I then return to the main screen.
does it read it to 100% then say that?
hulkster
Update: After a call with TS and a reset of the inTune code, the 91 CAI Tune was installed. I'm very anxious now for work to end so I can get the car out on the road. Thanks!
awesome, keep us posted
OK, ever since the intune freezing and my car note starting, my transmission has not been shifting right....very rough and when decelerating and then accelerating third gear vibrates.....any ideas to what happened...?
- JonDiablosport
remove the negative battery terminal for a few minutes please try that. this will allow the system to reset.
I took it off last night and let it stay off all night and this morning on the way to work is still was doing the same thing...?
What do I do now!!!?
call us with the tool in the vehicle please.
