Navi screen broke after install tune with Predator
mechelaar
Post by mechelaar »
After installation of tune, does the navi screen of no more why? Before I went to the tune install screen of vision always to no longer makes Predator problems with can-bus system? Someone had the same or similar problem? Has to help Chrysler dealer? Need urgent help please. In Germany there are not many specialists to dodge cars that could help thanks in advance Dieter
brandy16
RE: Navi screen broke after install tune with Predator
Post by brandy16 »
Put the original tune back in and see if you have the same problem.If you do its not the tune.
mechelaar
Post by mechelaar »
I'm back to all of the original version, the problem remains
Then its not the tune. Your car is broken.
mechelaar
Post by mechelaar »
Before I install tune everything was ok when I was finished with tune screen is off, the radio plays just the screen off. What makes predator in the bus system? When I tune everything and install switches off when finished install switched everything back to normal as everytime I tune changed habe.Das car drives with the new tune super.In Germany we drive on LPG Autogas he has spent 10% less energy-that's why I recently time to try what predator. Tomorrow I go to a buddy, and most any other navigation device.
brandy16
Post by brandy16 »
So with the tune installed every thing works or you still have no screen? but the car runs good.
mechelaar
Post by mechelaar »
brandy16 wrote:So with the tune installed every thing works or you still have no screen? but the car runs good.
yes,everything works except the screen, I meant when I org. backup everything back as before.I've done wierder tune on it,
brandy16
Post by brandy16 »
OK so every thing works including the screen after you put the original tune back in. If not then there is some thing wrong with the screen. Have you had the dash apart. Did you buy the car new. I would take the trim ring off around the radio and chechk the connections to make sure nothing has come loose.
mechelaar
Post by mechelaar »
brandy16 wrote:OK so every thing works including the screen after you put the original tune back in. If not then there is some thing wrong with the screen. Have you had the dash apart. Did you buy the car new. I would take the trim ring off around the radio and chechk the connections to make sure nothing has come loose.
The car was new 2007, have 44000 meils, today i testet anover navi the screen was good.
brandy16
Post by brandy16 »
Looks like you have a bad screen. The pedator did not cause your screen to go bad. I think it just happened to go bad at the same time you installed a tune.
mechelaar
Post by mechelaar »
yes, I may have a different navigation and bought a building there next week. Give it a possibility to octane with Predator set on 102?
mechelaar
Post by mechelaar »
mechelaar wrote:
brandy16 wrote:
mechelaar wrote: The car was new 2007, have 44000 meils, today i testet anover navi the screen was good.
sorry 102 europe oktan it´s 95 us oktan
