just bought a puck
just bought a puck
I have an 03.5 ctd with the 250hp motor.You guys say 60 and 90 hp gain.Is that with the HO or can i expect it with my motor as well?
RE: just bought a puck
Yes, you will see those gains.
I just installed my puck today.Then I started it to leave,I let it warm up for a bit since its 36 out today and when it went to go into a high idle for warm up it had a "rough idle" like a fast wawawawawa.even if i pushed the pedal to lower the rpms it just did it slower.i drove a couple of minutes to the store and still did it when i parked.I came out and was fine and is fine now.Is this normal?Is it a cold temp thing?I started it on stock by the way.
Yeah, sounds like a cold start thing, no biggie.
are you sure this is normal?because it never did it before I put in the puck.Also should I get an EGT gauge?Is that something i have to worry about with this,I already have a turbo back 4" exhaust too
if you run it on the stock setting it should tell you if it is different but it sounds like the warm up mode
04.5 dodge CTD, afe monster air intake, quad commander, quad X2, rokktech, auto tranny 4x4 quad cab
diesel bombs dropped here!
http://www.dieselbombers.com/register.p ... rrerid=300
