U7146 download stock tune rev 7r50d
Questions and comments specific to the DiabloSport Downloader application.
xmhotrods
Post by xmhotrods »
using u7146 rev 7r50d
1998 mustang cobra, stick
Trying to download stock tune with dsdownloader 2.2.2.6 wont work. Times out? Any ideas?
I looked for a older version of ds1740 but could not find it.
I know there has to be away. I also updated drivers did not make a difference. What settings should I try or do I need to get a copy of ds1740?
Ed@X&M Hot Rods
Mt. Pleasant, Mi 48858
Mobile Dynojet 248c
(989)430-9597
XMHOTRODS.COM
RE: U7146 download stock tune rev 7r50d
7r50d does not auto connect, set DSDL in legacy connect, and then export the backup
also have to configure the tool, options/custom tune/export tune, select backup.
Also, i assume you meant 1998 Cobra??
better option would be to update to the latest, then you can export backup from main menu using auto connect...
xmhotrods
Post by xmhotrods »
Yes you are correct 1998 Cobra I fixed it. No, I know it does not auto connect. I did do the legacy connect and change the baud rate as well. And I did go into the tool to export the stock tune. I tried for over an hour and could not get it to work. I would update it for him but the customer does not want it updated in that losing the functions on turning off o2 sensors and erg.
Ed@X&M Hot Rods
Mobile Dynojet 248c
(989)430-9597
XMHOTRODS.COM
wrong com port selected?
Not sure what else could be up, sometimes these older tools give me a hassle, but a quick change of operations is usually the fix...
xmhotrods
Post by xmhotrods »
using com3 and tried com2 no luck. Yea it is fighting me. I'll give it a try again in a little while. Do you have a copy of the old dsloader you could email me?
Ed@X&M Hot Rods
Mobile Dynojet 248c
(989)430-9597
XMHOTRODS.COM
not sure I have an old dsdl, but I just did this with a 7r50d tool and 2.2.2.6 here last week, worked fine...
xmhotrods
Post by xmhotrods »
ok thanks i'll reload software and try it again. I am using winxp not if it matters on sp3.
Ed@X&M Hot Rods
Mobile Dynojet 248c
(989)430-9597
XMHOTRODS.COM
same here :)
Return to “DS Downloader”
