Using a OBD2 splitter with a Predator
rudedog
Post by rudedog »
This also goes for an intune or trinity unit as well. I have a gauge that uses the OBD2 port and was wondering if you can use the preditor/intune/trinity along side to data log. I would never trust a splitter to update a tune but was wondering what Daiblosport thinks
Has DS ever tested this?
RE: Using a OBD2 splitter with a Predator
Nope. The more stuff you run, the slower the refresh rate. If you split it the rate will be too slow to log or monitor worth a damn.
rudedog
Post by rudedog »
Thanks for the reply Mike,
Is this something DS has tested? The reason I ask, is I have a hard time believing something that is connected in Parallel would cause the bus to slow down. Corrupted data maybe but adding latency, I'm not so sure.
Could these "splitters" be a serial device instead of a Parallel device?
Not that I don't believe you Mike, just trying to find the logic and science behind these devices (splitters). I've read a thread where service techs use a 8-12 way passive splitter to "read along" data with the teacher in real time when troubleshooting via the OBD II ports.
2010 Challenger R/T Classic | 6sp | STP | Lockpick v.4 w/cam | Trinity w/1r10g.crom | JBA shorties | Hi-flow cats | Hi-Flow exhaust | 85MM ported and polished TB | AFR hood w/CAI | 93 Oct. | hi performance 93Oct w/ CAI tune
Its something you can test for yourself. Keep adding PIDs and then do a log. When you play it back, you'll notice that the data refreshes much less frequently the more things you log.
