Application Number: 1r01g
Dodge Ram 1500 2009
When I connect my Intune to my computer and I click on INtune.exe I get the following message Please Connect An Intune First. I called tech support and He sent me an update via e-mail and the Intune got updated but still the same message still pop ups. Anyone could help me?
Please Connect Intune First!!!
RE: Please Connect Intune First!!!
is it telling you the driver is not installed?
right click on the intune.exe and select run as administrator, see if that helps.
Same thing here
Car on the dyno
3 hours later i still cannot use intune.
Car on the dyno
Re: RE: Please Connect Intune First!!!
is your issue with the driver?autox wrote:Same thing here
Car on the dyno
your email gave NO information to help you, Id dint even know what tool you were using...
This is a simple fix, which has been posted here time and again, right click the intune.exe, select run as administrator, and all set.
RE: Re: RE: Please Connect Intune First!!!
I had that issue and still with the administrator thingy didnt work at all! Sometimes there is more then one bug with the same result like please connect intune first. I had to ship it back and get a new one!
Ram 1500 2009 Laramie, Ds Intune, jba shorties, moes Tb, L&M custom Trans, Moes Catch can, E-Fan, Custom double exhaust 2.5 + x-pipes, Ripp SC
Again.. car on dyno... same intune.. .run as administrator doesn't work... its requesting a cal update and i can't update.
Please help.
Please help.
