prolific driver for my serial to usb adpt
brandy16
Post by brandy16 »
I have tried at least a dozen times to down load the prolific driver for windows 7 from the diablo down loads. The driver will install but will not work. Any ideas what might be causing the problem. The DS Down loader is not finding the predator.
RE: prolific driver for my serial to usb adpt
Running as Administrator?
brandy16
Re: RE: prolific driver for my serial to usb adpt
Post by brandy16 »
Mike_Levy wrote:Running as Administrator?
Yes I am. After downloading and installing the driver I checked to see if the driver was working in the devices and it said it was. When I plug in the predator and open DS down loader it just keeps searching but will not find the predator. Also down in the tool bar windows is telling me that it is installing the driver for my hardware and then says it did not get installed correctly. I had this problem on my XP based computer and after seems like 50 tries it finally worked (the driver). The Predator is not being found because the serial to usb adapter driver is not working. I down loaded the driver from the deablo down load site. Sorry for being so long winded. Thanks
RE: Re: RE: prolific driver for my serial to usb adpt
brandy16
Re: RE: Re: RE: prolific driver for my serial to usb adpt
Post by brandy16 »
Thank you I tryed the link but it says web page can not be found.
05ram2500
RE: Re: RE: Re: RE: prolific driver for my serial to usb adp
Post by 05ram2500 »
I could never get the prolific driver to work or any other driver to work with the cable that came with the interface kit, bought radio shack cable and boom worked like a champ.
Whoops, I linked the old file. This should be the one. http://www.cooldrives.com/lib/cooldrive ... rivers.zip
You may need to run in XP Compatibility Mode with this one.
brandy16
Post by brandy16 »
Sorry but how do I run the XP compatibility mode. Thanks for all your help.
Right click on the DSDL icon, go to Properties, then Compatibility, Check Run this program in Compatibility Mode for, Change the box to Windows XP Service Pack 3. Check Run this program as an Administrator, then OK.
brandy16
Re: RE: Re: RE: Re: RE: prolific driver for my serial to usb
Post by brandy16 »
Mike_Levy wrote:Right click on the DSDL icon, go to Properties, then Compatibility, Check Run this program in Compatibility Mode for, Change the box to Windows XP Service Pack 3. Check Run this program as an Administrator, then OK.
I did that and still not working. I have the prolific adapter maybe it's just a pice of crap thats not going to work. Is ther another serial to usb adpter I can buy that is better.
RE: Re: RE: Re: RE: Re: RE: prolific driver for my serial to
Radio Shack. Its the only one that never seems to not work.
brandy16
Re: RE: Re: RE: Re: RE: Re: RE: prolific driver for my seria
Post by brandy16 »
Mike_Levy wrote:Radio Shack. Its the only one that never seems to not work.
Ok I think I will get one from Radio Shack. Thanks for all the help.
RE: Re: RE: Re: RE: Re: RE: Re: RE: prolific driver for my s
NP. Good luck.
something has changed on Windows end that is causing these issues, not fun :)
EBEAL
Post by EBEAL »
mikel wrote:something has changed on Windows end that is causing these issues, not fun :)
WILL THIS CABLE WORK?
http://www.frys.com/product/6050648?sit ... IN_RSLT_PG
