2007 Charger SRT8 - "failed to read pcm original backup
RE: 2007 Charger SRT8 - "failed to read pcm original ba
bump....as requested
Is it okay for the intune to be powered on for that long?
It seems my computer restarted itself overnight which also restarted the intune. So here's the new key to use:
8B5113
5CA349
2DB05B
6262D1
6004F5
8B5113
5CA349
2DB05B
6262D1
6004F5
here you go:
551BB57E4F04C530
then click OK or next.
551BB57E4F04C530
Thanks. I will reset it when I get home and try it on the car. I'll let you know how it goes.
good deal.
Nope. It didn't work
I disconnected the battery for 15min...i made sure all electronics were off...I plugged it in and it detected my car fine. I got to the Diablo Tunes screen...but when I selected the tune....i got the same error "failed to read PCM original backup".
I even updated to the latest version 1r01H and tried it again still the same error. I turned on the car too and let it run for 5min....but I still got the same error.
Any other ideas as to whats causing this problem?
Here's my XML info...if it helps at all:
<tool_info>
<main full_version='InTune-1r01h 03/29/2012 12:07:10 PM' sw_rev='1r01h' svn='4210'/>
<registration sn='CICPN5D-1' status='0'/>
<restore id='0' vin='2B3LA73WX7H691659' bc='0'/>
<db mfr='GM' tune='1r01d' pid='1r01a'/>
<db mfr='DCX' tune='1r01a' pid='1r01a'/>
<db mfr='FORD' tune='1r01a' pid='1r01a'/>
<system_db dtc='1r01a' vin='1r01a' info='1r01a'/>
<license avail='1' tuned='0'/>
<updates count='1'/>
</tool_info>
<tool_info>
</tool_info>
Im not 100% sure, id almost like to just y replacing the tool, or getting it swapped out with the retailer at this point.
Oh ok. So what's the process of getting a replacement? Do I have to send it to you guys? Or do I contact the retailer? I got it from TdotPerformance in Canada (Toronto, Ontario)
Check with the retailer first, if they cant or wont, let me know
Alright. And is there any difference between doing the tool reset and doing a force calibration update? Jon was suggesting trying that and I have access to the car and the tool right now. I've been trying to call for the past 15min and still on hold.
Do you think a forcing a cal update might work?
it did a cal update to start with, correct?
its worth a shot..
I have 2 guys at lunch right now, it may take a few minutes to get through.
its worth a shot..
Yeah...it did a cal update the very first time I plugged it in. But not after the tool reset.
But I finally got through and spoke to Vas. Went through the procedure to do the Force Calibration Update. It did the cal update just fine...but still when I went write the tune, I got the same error. And Vas also agreed that there is probably an issue with the tool.
So I will contact the retailer to get a replacement.
I'll keep you posted.
Thanks.
Thanks.
similar problem with my 300c 5.7.
Hi I have a similar problem with my 300c 5.7 . Did you get any answers from diablo on how to fix the problem.
Re: similar problem with my 300c 5.7.
Please give us a call with the tool powered up in the vehicle.paulg10 wrote:Hi I have a similar problem with my 300c 5.7 . Did you get any answers from diablo on how to fix the problem.
RE: Re: similar problem with my 300c 5.7.
I finally received my replacement inTune. When I first plugged it in, it detected my car fine (it didnt do a calibration update though? maybe cause it was already done by the previous tuner?) I got to the diablo tunes and selected the 91 Octane tune but I got the same failed to read pcm original backup error when it was writing. So I plugged it into my PC and did all the updates. When it was done, I plugged it back into my car, tried again (selected 91 Octane tune) and still got the same error. I decided to try again, but this time I selected a different tune (Diablo Tune)....and again I got the same error. I tried the 91 Octane tune again and it worked!!
It created the backup and wrote the tune to the car. After it was finished, I plugged the tuner back into my PC and checked the tunes folder and the files were there. So I dont know if the tries back and forth between the different tunes may have helped...or if I just got lucky. Just wanted to share my process that I used to get it to work...maybe it will help some other ppl having this issue. I will be leaving the tune on my car for a few days and then trying to load different tunes to see if I still run into the same issue.
Thanks Diablosport support for the help...hopefully this has resolved my issue. I will try writing a different tune to my car at another time to see if my problem is completely gone.
Just had a question...what is the "Diablo Tune" option? is that the same as 93 Octane tune? and if it is...what would happen if I put that on and still used 91 Octane fuel in my car? Would it damage the engine?
