2005 Corvette erratic idle
BrentD
Post by BrentD »
Just received my intune today and installed the Diablo tune on my 2005 Corvette. Idle is very erratic. Uninstalled Diablo tune and reinstalled factory tune. How can I resolve this idle issue?
Satch606
RE: 2005 Corvette erratic idle
Post by Satch606 »
I had the same issue with my 2006 TBSS. Uploaded the tune file to Lew and he corrected it for me.
post the backup and LTW please, we'll fix it up for you.
Satch606
Post by Satch606 »
8)
dbauto
Post by dbauto »
Mine did the same thing they can fix that easily
BrentD
Post by BrentD »
How do I get the backup and LTW files? When I connect it to the computer the tunes folder is empty.
that's because you restored the original backup to your vehicle...
install one of the tunes to your car again so the intune saves copies of the original backup and last tune written files in itself...
then they will be in the tunes folder... then you can copy them to your PC and then post them up here... ;)
and yes, I know exactly what the issue is and can be fixed easily with a quick custom tune...
jpollard83
Post by jpollard83 »
Yep...i just installed it in my 06 TBSS this morning and i have the same issue.
Re: RE: 2005 Corvette erratic idle
jpollard83 wrote:Yep...i just installed it in my 06 TBSS this morning and i have the same issue.
grab the tunes from the tune folder on the intune drive and post them up here, we'll fix it up for you.
jpollard83
I hope i did this right...still trying to figure out how everything works.... Thanks - JJ
jpollard83
It was nowhere near as bad this morning as it has been...it usually is to the point of almost stalling out.
thats a log, we need the tunes...
need the two tune files that are in the TUNES folder on the inTune
jpollard83
Sorry...
ECM_12606497_Backup.grg
(39.09 KiB) Downloaded 155 times
ECM_12606497_LastTuneWritten.grg
(37.86 KiB) Downloaded 161 times
Tune for jpollard83
here ya go man...
save this file to your computer.. then copy/paste it into your intune into the TUNES folder and then the intune will import it...
then when that's done, you'll have the custom tune in the tune menu on the intune when you connect to your truck...
select the custom tune to install and you're good to go....
ecm_12606497_fixed.grg
(35.31 KiB) Downloaded 139 times
