How to get 95 Octane
Fastvettenor
Post by Fastvettenor »
Hello.
I have just installed the Trinity on my 2001 Corvette C5 Z06 and have the following questions:
1. I was not prompted to select the vehicle. I was just promted to select manual or automatic. is there something wrong since I did not get to select this, or did the Trinity find my car automaticly.
2. When selectiong performance I was only able to select 87 and 91 octane. Why did i not get an option to select 93 or 95 octane? How can i change it to a higher octane?
I will appreciate any answer thank you.
RE: How to get 95 Octane
We do not offer a 95 octane tune, as we do not get 95 octane anywhere.
You should have a 93 tune, it may be called the 'diablo tune'.
won't have a 95 octane tune... I'm guessing you're not in the U.S... your 95 octane gas is equivalent to our 91 octane gas...
the Diablo Tune is for our 93 octane gas - which would be your 98 octane...
on the trinity, go to options - change vehicle type and go through that and select your vehicle info...
Fastvettenor
Re: RE: How to get 95 Octane
06MonteSS wrote:won't have a 95 octane tune... I'm guessing you're not in the U.S... your 95 octane gas is equivalent to our 91 octane gas...
Thank you. Yes I live in Europe, and we have Shell 99 octane (US RON 95 and at Nurburgring we have 102 Octane (US RON 98)
I had to restore the back up file and install the Diablo Tune. Thanks to the forum I figured it out, ... BUT... to be able to utilize the 102 RON..should I then change WOT, or will the diablo tune work even better with the 102 without any mod?? If I want to change the WOT..do i increase or decrease the values?? Is there any manual that shows how much the values should be changed??
Fastvettenor
mikel wrote:We do not offer a 95 octane tune, as we do not get 95 octane anywhere.
Thank you. I found the Diablo tune as it was the only option after selecting the car and resetting the original tune. ( I have also posted a new question about WOT later down... if you mind looking at it..)
Regards
Arne
Return to “Trinity GM Gas”
