Is Intune the answer?
jaimeson55
Post by jaimeson55 »
I need a easier way of comparing maps and the predator is slow as dirt. I really would like a single use CMR for end user. My question is can Intune give me more of a computer feel or any access to maps on the computer?
RE: Is Intune the answer?
No...
Rpmextreme
Post by Rpmextreme »
most guy's that will sell you a tune will probably lock it anyway and you won't be able to see it even if you had CMR.
there is no way to do what your trying to do with just the adjustments on any tool. you will need CMR and knowledge or someone with CMR to write you several tunes and to work with your datalogs, its easy to get WOT dialed in on the dyno.....the hard part is driveability and such.
I would put 8 psi max on your jeep and run 93 octane fuel and call it a day. my 2011 auto JK has almost too much power as it is at 8 psi.
Tuneable 2011 custom JEEP JK ecu's
Supercharger kits & Tuning
www.rpmextreme.com
