a quick question.....
sickREDsierra
Post by sickREDsierra »
i just have a quick question....... when i pull up my adjustable parameters, under speed limiter, there are two options....
with etc
without etc
i assume etc is electronic throttle control, but i am not sure..... i set it "with etc", and it worked to raise my speed limiter, but i was just curious if this was the correct choice to make. my throttle IS electronically controlled on my vehicle, "fly by wire".
thank you
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
RE: a quick question.....
yes, it's for Electronic Throttle Control... you made the right choice my son... may the force be with you...
:lol:
sickREDsierra
cool. i was pretty sure i was an intelligent mother fonger, but you have assured me in my assumption.
now my old lady will want me even more! LOL!!!!!!!!
seriously though, i set it for 125, which is the max it will allow me, but it took me about a day and a half to get to that mark! i am really needing a different camshaft in my engine, it just doesnt pull like it should....plus the gears in the rear suck! oh well, something else to spend my money on.
later
crazy27
Post by crazy27 »
damn serria havin fun aint we???
2k silverado 1500 exd cab long bed
5.3L gen III
k&n 77series cai
airraid spacer
160 thremo
grantelli mpg wires 8.5
E-3 plugs
flowmaster 50 series 3' in 3"'out single
22' 1piece 5 spoke ADR wrapped in 305/40/22
u7198 predator with mod tune..
Re: RE: a quick question.....
sickREDsierra wrote:cool. i was pretty sure i was an intelligent mother fonger, but you have assured me in my assumption.
later
I've seen good things from the LS6 cam in the 4.8/5.3 motors, they really wake up.
sickREDsierra
RE: Re: RE: a quick question.....
well, i was going to go that route, but the lift is a little higher on that cam than what i want <.550-.560> my friend has a cam he is GIVING me out of an 02 ss camaro...aftermarket grind .530 lift, 216/218 druation on a 116 lobe sep........i think it will be VERY well suited for my needs, and the price is PERFECT!!!! i will use the yellow LS6 springs though, and probably a set of titanium retainers......then the pacesetter LT headers with ORY and cat deletes....
that should do me in.....maybe i can keep my tranny together, and i think my predator will still be enough for me if i stop there......i dont want to have to get a new laptop....but wheatley tuning and nelson tuning are both outstanding options....
i like my little predator though.
later mikey
