Here is a video of what is going on.
http://www.youtube.com/watch?v=X9cD-vvo9Ak
Data logging not working
jaimeson55
RE: Data logging not working
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM7 at 115200 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Predator'.
Serial number = '218151332'.
Part number = 'u7137'.
CROM version = 'u7137-9r13 10/28/2011 07:44:55 PM boot3'.
Vehicle VIN = xxxxxxxxxxxxxxxxxxxxxxxx
Vehicle Calibration = '68043467AH'.
Original backup SAVED.
Tool is Married TRUE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is NOT supported.
Tool SUPPORTS multiple ECUs.
Tool reports 1 ECUs.
Multi ECU Backups : 1
Marriage VIN : xxxxxxxxxxxxxxxxxxxxxxxxxx
Tool ID :
Desc :
PCM : 68043467AH
Multi ECU Tuning : 1
Name: PCM, TuneID: 68043467ah_ripp_3,3.drg, Modified: yes, Lock: Yes, Erased: No
Server:
Tool ID :
Desc :
PCM : 68043467AH
Server:
- Rpmextreme
download dsdataviewer. install it on your laptop. hook diablo up to jeep and then plug into laptop and start dsdataviewer. it will go out and find the best pids aviable and will set up for recording. much easier than using the predator to do it on its own.
you can also view the data in real time. im sure there is a sticky somewhere on how to datalog.
jaimeson55
Helpful as usual, diablo should have you on payroll
- Rpmextreme
you hear that diablo? I like Florida LOL
Re: RE: Data logging not working
HA!!Rpmextreme wrote:you hear that diablo? I like Florida LOL
Come on down!!!!!!
- Rpmextreme
RE: Re: RE: Data logging not working
I wouldnt get much work done down there. Too much sunshine and bikinis, im more comfortable with tornadoes and rednecks
Re: RE: Re: RE: Data logging not working
lol...I hear ya.Rpmextreme wrote:I wouldnt get much work done down there. Too much sunshine and bikinis, im more comfortable with tornadoes and rednecks
Me and a few of the guys often go over to the beach for lunch...its not easy to come back to work. The beach is all of .5 miles east of us....
Down side is, when there is a hurricane, the beach is only .5 miles away
