Oh come on!! Now what? P1101
P1101 - Actual measured airflow from MAF, MAP, EGR, and TP is not within range of the calculated airflow
Well maybe your calculations are off!! :roll: First thought, air leak after the MAF. Checked, all good. No idea what else it could possibly be.
Can this be fixed in the tune? 2100 miles and she's already throwing codes! :x
RE: Oh come on!! Now what? P1101
I have a feeling we may have seen this before...this a 2011 right?
Yes, 2011 CTS-V
yeah, if I recall correctly we have had a few modded 2011 models throw that code, Johan should have a fix...too bad he didn;t come in today ;)
Did Johan come to work today?
yup...
She threw the code again tonight. Is there a fix for it, or should I just keep clearing it? It seems to pop up when I go WOT.
Its likely just in need of some tuning...
Conditions for Setting the DTC
The engine control module (ECM) detects that the actual measured airflow from the MAF, MAP, SC Inlet Pressure, and the TP sensors are not within a range of the calculated airflow that are derived from the system of models by greater than a calibrated threshold for greater than 10 s.
Return to “Trinity GM Gas”
