intune.exe issues
PhatBasturd
Post by PhatBasturd »
NO JOY. Still does not work - same symptoms.
please open the intune drive and post the info.xml file here, and also tell me if there is an .itfg file on the intune drive, and if there is, delete it :)
PhatBasturd
Yes there is a Group_Update.itfg
Here is the xml:
<?xml version="1.0"?>
-<tool_info> <main svn="4210" sw_rev="1r01h" full_version="InTune-1r01h 03/29/2012 12:07:10 PM"/> <registration status="0" sn="CIDKXE2-1"/> <restore bc="0" vin="" id="0"/> <db pid="1r01a" tune="1r01c" mfr="GM"/> <db pid="1r01a" tune="1r01a" mfr="DCX"/> <db pid="1r01a" tune="1r01a" mfr="FORD"/> <system_db vin="1r01a" info="1r01a" dtc="1r01a"/> <license tuned="0" avail="1"/> <updates count="2"/> </tool_info>
PhatBasturd
I deleted the itfg file and rebooted the inTune.
It is currently writing to the inTune.
sweet, that should be the fix.
ptperformance
Post by ptperformance »
Wow what a pain to get sorted. I had one of my InTunes do the same thing and I had to drop both files into the "intune" folder. After that, updates and everything is running smooth.
Thanks guys!
autox
Post by autox »
Same thing here... UAC stuff is off.. and has always been off!
autox
Post by autox »
I cannot update it because it needs to be registered. or so that says on the display
but i can't registered it because it can't be detected!
autox wrote:I cannot update it because it needs to be registered. or so that says on the display
if you post the actual info.xml file, I can both get you the needed cal update, and make you a registration file....
prplhze
Post by prplhze »
[quote="mikel"][quote="autox"]I cannot update it because it needs to be registered. or so that says on the display
but i canSame here please...
inTune worked fine on update 1r01h now wont work at all with 1r01i. And I have never been able to register. I never get a PIN code sent to my e-mail after filling out the reg form.
-<tool_info> <main svn="4599" sw_rev="1r01i" full_version="InTune-1r01i 05/15/2012 10:38:04 AM"/> <registration status="0" sn="CIE8B96-1"/> <restore bc="0" vin="2B3CJ7DW9AH199744" id="0"/> <db pid="1r01a" tune="1r01e" mfr="GM"/> <db pid="1r01a" tune="1r01b" mfr="DCX"/> <db pid="1r01a" tune="1r01b" mfr="FORD"/> <system_db vin="1r01a" info="1r01a" dtc="1r01a"/> <license tuned="0" avail="1"/> <unsupported vin="2B3CJ7DW9AH199744" oem="DCX" calid="68004309AD"/> <updates count="2"/> </tool_info>
JonDiablosport
Post by JonDiablosport »
the registration screen has been completely revamped with 1r01i. even before it was released actually. and you are posting the contents of the info file not the actual info file. Please choose post reply and attach the info.xml file to the post. thanks;
or email it to [email protected]
Diablosport Tech support
p: 561-908-0040
F: 561-908-0048
prplhze
Post by prplhze »
Hope this helps...
When I try to load a tune, inTune says "Exit Called".
prplhze
Post by prplhze »
If I try to load another tune it also reads "vehicle has been tuned previously by another DiabloSport product". This is the only tuner I have.
Can I get cal update and registration file??
prplhze
Post by prplhze »
Also, logs folder and tunes folder are empty.
what vehicle do you have?
