hi can any one help me please i have predator U7146 can you please send me the best tuning for my cobra 99 stock only bbk coldair and magnaflow cat-back only and rear tire size 295/45/ ZR18
and i need all this if possible :
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
On/Off switch for Traction Control
Raise Speed Limiter
Rev Limiter
Re-Calibrate Speedometer for Gear and Tire Size Changes
Shift Pressure
RPM Shift Points
Torque Modulation (for better shift feel)
Cooling Fan ON/OFF Temperatures
Rear Oxygen sensor disable (use for off-road vehicles only)
cobra 99
RE: cobra 99
Wow, what a request! I'm not sure how you missed it, but you already have all of those options in your Predator.
If you look in the owners manual, it will explain how to access the modify parameters menu.
Make sure you have the latest 7r50d revision on your Predator as well.
Thank you
Thank you
