idle issues
idle issues
when I let it warm up for a bit since its 36 out today and when it went to go into a high idle for warm up it had a "rough idle" like a fast wawawawawa.even if i pushed the pedal to lower the rpms it just did it slower.i drove a couple of minutes to the store and still did it when i parked.I came out and was fine and is fine now.Is this normal?Is it a cold temp thing?I started it on stock by the way.It still does this all the time and the idle over all just seems rougher.Any ideas whats causing this?
RE: idle issues
Possibly the cold weather (not used to that here in FL!). Try taking the Puck off and see what happens.
Christy High
lurker.
lurker.
RE: idle issues
I unhooked my puck and the truck idles prefectly at high idle(1100-1200rpms).and at normal 700 rpms.And its 17 degrees right now.
